SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.001543
SELECT cache_value
Params: 1
Run Time: 0.000220
LIMIT 1
Run Time: 0.000588
WHERE
AND frtRead.read_date IS NULL
AND (frtThread.expire_date > 1714208205 OR frtThread.expire_date = 0)
AND view_global = 1
AND active = 1
ORDER BY frtThread.order
Params: 0
Run Time: 0.000509
FROM `xf_thread`
WHERE (`xf_thread`.`thread_id` = '3094')
LIMIT 1
Run Time: 0.000681
WHERE
AND (FIND_IN_SET (14, node_ids) OR node_ids = '')
AND active = 1
Params: 0
Run Time: 0.000445
SELECT cache_value
AND content_type = ?
AND content_id = ?
Params: 1, node, 14
Run Time: 0.000193
FROM `xf_post`
WHERE (`xf_post`.`thread_id` = 3094) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 40) AND (`xf_post`.`position` < 60)
Run Time: 0.008477
-- XFDB=noForceAllWrite
INSERT INTO xf_thread_view
(thread_id, total)
VALUES
(? , 1)
ON DUPLICATE KEY UPDATE
total = total + 1
Params: 3094
Run Time: 0.000102
SELECT `xf_user`.*
FROM `xf_user`
WHERE (`xf_user`.`user_id` IN (224, 2128, 13, 10))
Run Time: 0.000592
SIMPLE | xf_user | range | PRIMARY | PRIMARY | 4 | | 4 | Using where |
FROM `xf_snog_forms_forms`
WHERE (`xf_snog_forms_forms`.`oldthread` > '0') AND (`xf_snog_forms_forms`.`oldthread` = 3094)
LIMIT 1
Run Time: 0.000710
SELECT view_date
FROM xf_session_activity
Params: 0, �S�
Run Time: 0.000180
UPDATE xf_session_activity
SET
ip = ?,
controller_name = ?,
controller_action = ?,
view_state = ?,
params = ?,
view_date = ?,
robot_key = ?
Params: �S�, XF\Pub\Controller\Thread, Index, valid, thread_id=3094&page=3, 1714208205, , 0, �S�
Run Time: 0.000150
bytes_sent | 12427 |
bytes_received | 708253 |
packets_sent | 148 |
packets_received | 1336 |
protocol_overhead_in | 5344 |
protocol_overhead_out | 592 |
bytes_received_rset_header_packet | 504 |
bytes_received_rset_row_packet | 195 |
bytes_received_prepare_response_packet | 86698 |
bytes_received_change_user_packet | 620258 |
packets_sent_command | 73 |
packets_received_ok | 0 |
packets_received_eof | 0 |
packets_received_rset_header | 56 |
packets_received_rset_row | 26 |
packets_received_prepare_response | 1116 |
packets_received_change_user | 112 |
result_set_queries | 22 |
non_result_set_queries | 4 |
no_index_used | 2 |
bad_index_used | 0 |
slow_queries | 0 |
buffered_sets | 0 |
unbuffered_sets | 0 |
ps_buffered_sets | 22 |
ps_unbuffered_sets | 0 |
flushed_normal_sets | 0 |
flushed_ps_sets | 0 |
ps_prepared_once_executed | 23 |
rows_fetched_from_server_ps | 90 |
rows_buffered_from_client_ps | 90 |
rows_affected_normal | 0 |
rows_affected_ps | 0 |
rows_skipped_normal | 0 |
rows_skipped_ps | 0 |
copy_on_write_saved | 0 |
copy_on_write_performed | 0 |
connect_success | 1 |
connect_failure | 0 |
connection_reused | 0 |
reconnect | 0 |
pconnect_success | 1 |
active_connections | 1 |
explicit_close | 0 |
implicit_close | 0 |
disconnect_close | 0 |
explicit_free_result | 0 |
implicit_free_result | 21 |
explicit_stmt_close | 0 |
implicit_stmt_close | 0 |
mem_emalloc_count | 0 |
mem_emalloc_amount | 0 |
mem_ecalloc_count | 0 |
mem_ecalloc_amount | 0 |
mem_erealloc_count | 0 |
mem_erealloc_amount | 0 |
mem_efree_count | 0 |
mem_efree_amount | 0 |
mem_malloc_count | 0 |
mem_malloc_amount | 0 |
mem_calloc_count | 0 |
mem_calloc_amount | 0 |
mem_realloc_count | 0 |
mem_realloc_amount | 0 |
mem_free_count | 0 |
mem_free_amount | 0 |
mem_estrndup_count | 0 |
mem_strndup_count | 0 |
mem_estrdup_count | 0 |
mem_strdup_count | 0 |
mem_edupl_count | 0 |
mem_dupl_count | 0 |
proto_text_fetched_null | 0 |
proto_text_fetched_bit | 0 |
proto_text_fetched_int | 0 |
proto_text_fetched_date | 0 |
proto_text_fetched_year | 0 |
proto_text_fetched_time | 0 |
proto_text_fetched_blob | 0 |
proto_text_fetched_enum | 0 |
proto_text_fetched_set | 0 |
proto_binary_fetched_bit | 495 |
proto_binary_fetched_short | 478 |
proto_binary_fetched_int24 | 162 |
proto_binary_fetched_bigint | 1021 |
proto_binary_fetched_decimal | 23 |
proto_binary_fetched_json | 758 |
proto_binary_fetched_blob | 388 |
com_quit | 0 |
com_init_db | 0 |
com_query | 2 |
com_field_list | 0 |
com_create_db | 0 |
com_drop_db | 0 |
com_refresh | 0 |
com_shutdown | 0 |
com_statistics | 0 |
com_process_info | 0 |
com_connect | 0 |
com_process_kill | 0 |
com_debug | 0 |
com_ping | 0 |
com_time | 0 |
com_delayed_insert | 0 |
com_change_user | 0 |
com_binlog_dump | 0 |
com_table_dump | 0 |
com_connect_out | 0 |
com_register_slave | 0 |
com_stmt_prepare | 24 |
com_stmt_execute | 24 |
com_stmt_send_long_data | 0 |
com_stmt_close | 23 |
com_stmt_reset | 0 |
com_stmt_set_option | 0 |
com_stmt_fetch | 0 |
com_deamon | 0 |
bytes_received_real_data_ps | 617967 |
