SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.001401
SELECT cache_value
Params: 1
Run Time: 0.000193
LIMIT 1
Run Time: 0.000559
SELECT `xf_thread`.*, `xf_user_User_1`.*, `xf_snog_forms_forms_Form_2`.*, `xf_forum_Forum_3`.*, `xf_node_Node_4`.*, `xf_permission_cache_content_Permissions_5`.*
FROM `xf_thread`
LEFT JOIN `xf_user` AS `xf_user_User_1` ON (`xf_user_User_1`.`user_id` = `xf_thread`.`user_id`)
LEFT JOIN `xf_snog_forms_forms` AS `xf_snog_forms_forms_Form_2` ON (`xf_snog_forms_forms_Form_2`.`oldthread` > '0' AND `xf_snog_forms_forms_Form_2`.`oldthread` = `xf_thread`.`thread_id`)
LEFT JOIN `xf_forum` AS `xf_forum_Forum_3` ON (`xf_forum_Forum_3`.`node_id` = `xf_thread`.`node_id`)
LEFT JOIN `xf_node` AS `xf_node_Node_4` ON (`xf_node_Node_4`.`node_id` = `xf_forum_Forum_3`.`node_id`)
LEFT JOIN `xf_permission_cache_content` AS `xf_permission_cache_content_Permissions_5` ON (`xf_permission_cache_content_Permissions_5`.`content_type` = 'node' AND `xf_permission_cache_content_Permissions_5`.`content_id` = `xf_node_Node_4`.`node_id` AND `xf_permission_cache_content_Permissions_5`.`permission_combination_id` = '1')
WHERE (`xf_thread`.`thread_id` = '6412')
LIMIT 1
Run Time: 0.001639
SIMPLE | xf_snog_forms_forms_Form_2 | ref | oldthread | oldthread | 4 | const | 1 | Using where |
SIMPLE | xf_forum_Forum_3 | eq_ref | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | xf_node_Node_4 | eq_ref | PRIMARY | PRIMARY | 4 | talo8211_xf.xf_forum_Forum_3.node_id | 1 | Using where |
SIMPLE | xf_permission_cache_content_Permissions_5 | eq_ref | PRIMARY | PRIMARY | 35 | const,const,talo8211_xf.xf_node_Node_4.node_id | 1 | Using where |
- XF\Mvc\Entity\Manager->find() in src/XF/Pub/Controller/Thread.php at line 1635
- Snog\Forms\XF\Pub\Controller\Thread->actionIndex() in src/XF/Mvc/Dispatcher.php at line 352
FROM `xf_post`
WHERE (`xf_post`.`thread_id` = 6412) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 120) AND (`xf_post`.`position` < 140)
Run Time: 0.001841
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 16 | Using index condition; Using where; Using filesort |
-- XFDB=noForceAllWrite
INSERT INTO xf_thread_view
(thread_id, total)
VALUES
(? , 1)
ON DUPLICATE KEY UPDATE
total = total + 1
Params: 6412
Run Time: 0.000090
SELECT view_date
FROM xf_session_activity
Params: 0, U�
Run Time: 0.000167
UPDATE xf_session_activity
SET
ip = ?,
controller_name = ?,
controller_action = ?,
view_state = ?,
params = ?,
view_date = ?,
robot_key = ?
Params: U�, XF\Pub\Controller\Thread, Index, valid, thread_id=6412&page=7, 1711646095, , 0, U�
Run Time: 0.000573
bytes_sent | 9605 |
bytes_received | 675274 |
packets_sent | 88 |
packets_received | 1099 |
protocol_overhead_in | 4396 |
protocol_overhead_out | 352 |
bytes_received_rset_header_packet | 270 |
bytes_received_rset_row_packet | 145 |
bytes_received_prepare_response_packet | 80212 |
bytes_received_change_user_packet | 594259 |
packets_sent_command | 43 |
packets_received_ok | 0 |
packets_received_eof | 0 |
packets_received_rset_header | 30 |
packets_received_rset_row | 16 |
packets_received_prepare_response | 948 |
packets_received_change_user | 89 |
result_set_queries | 12 |
non_result_set_queries | 4 |
no_index_used | 0 |
bad_index_used | 0 |
slow_queries | 0 |
buffered_sets | 0 |
unbuffered_sets | 0 |
ps_buffered_sets | 12 |
ps_unbuffered_sets | 0 |
flushed_normal_sets | 0 |
flushed_ps_sets | 0 |
ps_prepared_once_executed | 13 |
rows_fetched_from_server_ps | 77 |
rows_buffered_from_client_ps | 77 |
rows_affected_normal | 0 |
rows_affected_ps | 0 |
rows_skipped_normal | 0 |
rows_skipped_ps | 0 |
copy_on_write_saved | 0 |
copy_on_write_performed | 0 |
connect_success | 1 |
connect_failure | 0 |
connection_reused | 0 |
reconnect | 0 |
pconnect_success | 1 |
active_connections | 1 |
explicit_close | 0 |
implicit_close | 0 |
disconnect_close | 0 |
explicit_free_result | 0 |
implicit_free_result | 11 |
explicit_stmt_close | 0 |
implicit_stmt_close | 0 |
mem_emalloc_count | 0 |
mem_emalloc_amount | 0 |
mem_ecalloc_count | 0 |
mem_ecalloc_amount | 0 |
mem_erealloc_count | 0 |
mem_erealloc_amount | 0 |
mem_efree_count | 0 |
mem_efree_amount | 0 |
mem_malloc_count | 0 |
mem_malloc_amount | 0 |
mem_calloc_count | 0 |
mem_calloc_amount | 0 |
mem_realloc_count | 0 |
mem_realloc_amount | 0 |
mem_free_count | 0 |
mem_free_amount | 0 |
mem_estrndup_count | 0 |
mem_strndup_count | 0 |
mem_estrdup_count | 0 |
mem_strdup_count | 0 |
mem_edupl_count | 0 |
mem_dupl_count | 0 |
proto_text_fetched_null | 0 |
proto_text_fetched_bit | 0 |
proto_text_fetched_int | 0 |
proto_text_fetched_date | 0 |
proto_text_fetched_year | 0 |
proto_text_fetched_time | 0 |
proto_text_fetched_blob | 0 |
proto_text_fetched_enum | 0 |
proto_text_fetched_set | 0 |
proto_binary_fetched_bit | 482 |
proto_binary_fetched_short | 368 |
proto_binary_fetched_int24 | 119 |
proto_binary_fetched_bigint | 765 |
proto_binary_fetched_decimal | 19 |
proto_binary_fetched_json | 611 |
proto_binary_fetched_blob | 324 |
com_quit | 0 |
com_init_db | 0 |
com_query | 2 |
com_field_list | 0 |
com_create_db | 0 |
com_drop_db | 0 |
com_refresh | 0 |
com_shutdown | 0 |
com_statistics | 0 |
com_process_info | 0 |
com_connect | 0 |
com_process_kill | 0 |
com_debug | 0 |
com_ping | 0 |
com_time | 0 |
com_delayed_insert | 0 |
com_change_user | 0 |
com_binlog_dump | 0 |
com_table_dump | 0 |
com_connect_out | 0 |
com_register_slave | 0 |
com_stmt_prepare | 14 |
com_stmt_execute | 14 |
com_stmt_send_long_data | 0 |
com_stmt_close | 13 |
com_stmt_reset | 0 |
com_stmt_set_option | 0 |
com_stmt_fetch | 0 |
com_deamon | 0 |
bytes_received_real_data_ps | 592376 |
