SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.001955
SELECT cache_value
Params: 1
Run Time: 0.000249
LIMIT 1
Run Time: 0.000561
SELECT `xf_thread`.*, `xf_user_User_1`.*, `xf_snog_forms_forms_Form_2`.*, `xf_forum_Forum_3`.*, `xf_node_Node_4`.*, `xf_permission_cache_content_Permissions_5`.*
FROM `xf_thread`
LEFT JOIN `xf_user` AS `xf_user_User_1` ON (`xf_user_User_1`.`user_id` = `xf_thread`.`user_id`)
LEFT JOIN `xf_snog_forms_forms` AS `xf_snog_forms_forms_Form_2` ON (`xf_snog_forms_forms_Form_2`.`oldthread` > '0' AND `xf_snog_forms_forms_Form_2`.`oldthread` = `xf_thread`.`thread_id`)
LEFT JOIN `xf_forum` AS `xf_forum_Forum_3` ON (`xf_forum_Forum_3`.`node_id` = `xf_thread`.`node_id`)
LEFT JOIN `xf_node` AS `xf_node_Node_4` ON (`xf_node_Node_4`.`node_id` = `xf_forum_Forum_3`.`node_id`)
LEFT JOIN `xf_permission_cache_content` AS `xf_permission_cache_content_Permissions_5` ON (`xf_permission_cache_content_Permissions_5`.`content_type` = 'node' AND `xf_permission_cache_content_Permissions_5`.`content_id` = `xf_node_Node_4`.`node_id` AND `xf_permission_cache_content_Permissions_5`.`permission_combination_id` = '1')
WHERE (`xf_thread`.`thread_id` = '8078')
LIMIT 1
Run Time: 0.001681
SIMPLE | xf_snog_forms_forms_Form_2 | ref | oldthread | oldthread | 4 | const | 1 | Using where |
SIMPLE | xf_forum_Forum_3 | eq_ref | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | xf_node_Node_4 | eq_ref | PRIMARY | PRIMARY | 4 | talo8211_xf.xf_forum_Forum_3.node_id | 1 | Using where |
SIMPLE | xf_permission_cache_content_Permissions_5 | eq_ref | PRIMARY | PRIMARY | 35 | const,const,talo8211_xf.xf_node_Node_4.node_id | 1 | Using where |
- XF\Mvc\Entity\Manager->find() in src/XF/Pub/Controller/Thread.php at line 1635
- Snog\Forms\XF\Pub\Controller\Thread->actionIndex() in src/XF/Mvc/Dispatcher.php at line 352
FROM `xf_post`
WHERE (`xf_post`.`thread_id` = 8078) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003209
FROM `xf_attachment`
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (170650, 170677, 170678))
Run Time: 0.000958
SIMPLE | xf_attachment | range | content_type_id_date | content_type_id_date | 31 | | 11 | Using index condition; Using filesort |
-- XFDB=noForceAllWrite
INSERT INTO xf_thread_view
(thread_id, total)
VALUES
(? , 1)
ON DUPLICATE KEY UPDATE
total = total + 1
Params: 8078
Run Time: 0.000137
SELECT view_date
FROM xf_session_activity
Params: 0, \�
Run Time: 0.000316
UPDATE xf_session_activity
SET
ip = ?,
controller_name = ?,
controller_action = ?,
view_state = ?,
params = ?,
view_date = ?,
robot_key = ?
Params: \�, XF\Pub\Controller\Thread, Index, valid, thread_id=8078, 1711714044, , 0, \�
Run Time: 0.000176
SELECT `xf_session_activity`.*
FROM `xf_session_activity`
WHERE (`xf_session_activity`.`user_id` = 7) AND (`xf_session_activity`.`unique_key` = '7')
LIMIT 1
Run Time: 0.000265
- XF\Mvc\Entity\Entity->__get() in src/XF/Entity/User.php at line 313
- XF\Entity\User->getLastActivity() in src/XF/Mvc/Entity/Entity.php at line 167
- XF\Mvc\Entity\Entity->__get() in src/XF/Entity/User.php at line 522
- XF\Entity\User->canViewOnlineStatus() in src/XF/Entity/User.php at line 241
- XF\Entity\User->isOnline() in src/XF/Template/Templater.php at line 1195
- XF\Template\Templater->method() in internal_data/code_cache/templates/l2/s2/public/message_macros.php at line 27
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s2/public/post_macros.php at line 26
- XF\Template\Templater->renderExtension() in internal_data/code_cache/templates/l2/s2/public/post_macros.php at line 154
SELECT `xf_unfurl_result`.*
FROM `xf_unfurl_result`
WHERE (`xf_unfurl_result`.`url_hash` = 'c566e1d5dc4b56ff7435836dd7e3433d')
LIMIT 1
Run Time: 0.000234
WHERE (`xf_unfurl_result`.`url_hash` = '8422341dcc2290e1b1874c2333e94c43')
LIMIT 1
Run Time: 0.000243
bytes_sent | 11814 |
bytes_received | 716473 |
packets_sent | 136 |
packets_received | 1341 |
protocol_overhead_in | 5364 |
protocol_overhead_out | 544 |
bytes_received_rset_header_packet | 414 |
bytes_received_rset_row_packet | 185 |
bytes_received_prepare_response_packet | 92018 |
bytes_received_change_user_packet | 623300 |
packets_sent_command | 67 |
packets_received_ok | 0 |
packets_received_eof | 0 |
packets_received_rset_header | 46 |
packets_received_rset_row | 24 |
packets_received_prepare_response | 1130 |
packets_received_change_user | 117 |
result_set_queries | 20 |
non_result_set_queries | 4 |
no_index_used | 0 |
bad_index_used | 0 |
slow_queries | 0 |
buffered_sets | 0 |
unbuffered_sets | 0 |
ps_buffered_sets | 20 |
ps_unbuffered_sets | 0 |
flushed_normal_sets | 0 |
flushed_ps_sets | 0 |
ps_prepared_once_executed | 21 |
rows_fetched_from_server_ps | 97 |
rows_buffered_from_client_ps | 97 |
rows_affected_normal | 0 |
rows_affected_ps | 0 |
rows_skipped_normal | 0 |
rows_skipped_ps | 0 |
copy_on_write_saved | 0 |
copy_on_write_performed | 0 |
connect_success | 1 |
connect_failure | 0 |
connection_reused | 0 |
reconnect | 0 |
pconnect_success | 1 |
active_connections | 1 |
explicit_close | 0 |
implicit_close | 0 |
disconnect_close | 0 |
explicit_free_result | 0 |
implicit_free_result | 19 |
explicit_stmt_close | 0 |
implicit_stmt_close | 0 |
mem_emalloc_count | 0 |
mem_emalloc_amount | 0 |
mem_ecalloc_count | 0 |
mem_ecalloc_amount | 0 |
mem_erealloc_count | 0 |
mem_erealloc_amount | 0 |
mem_efree_count | 0 |
mem_efree_amount | 0 |
mem_malloc_count | 0 |
mem_malloc_amount | 0 |
mem_calloc_count | 0 |
mem_calloc_amount | 0 |
mem_realloc_count | 0 |
mem_realloc_amount | 0 |
mem_free_count | 0 |
mem_free_amount | 0 |
mem_estrndup_count | 0 |
mem_strndup_count | 0 |
mem_estrdup_count | 0 |
mem_strdup_count | 0 |
mem_edupl_count | 0 |
mem_dupl_count | 0 |
proto_text_fetched_null | 0 |
proto_text_fetched_bit | 0 |
proto_text_fetched_int | 0 |
proto_text_fetched_date | 0 |
proto_text_fetched_year | 0 |
proto_text_fetched_time | 0 |
proto_text_fetched_blob | 0 |
proto_text_fetched_enum | 0 |
proto_text_fetched_set | 0 |
proto_binary_fetched_bit | 558 |
proto_binary_fetched_short | 467 |
proto_binary_fetched_int24 | 147 |
proto_binary_fetched_bigint | 1114 |
proto_binary_fetched_decimal | 35 |
proto_binary_fetched_json | 820 |
proto_binary_fetched_blob | 391 |
com_quit | 0 |
com_init_db | 0 |
com_query | 2 |
com_field_list | 0 |
com_create_db | 0 |
com_drop_db | 0 |
com_refresh | 0 |
com_shutdown | 0 |
com_statistics | 0 |
com_process_info | 0 |
com_connect | 0 |
com_process_kill | 0 |
com_debug | 0 |
com_ping | 0 |
com_time | 0 |
com_delayed_insert | 0 |
com_change_user | 0 |
com_binlog_dump | 0 |
com_table_dump | 0 |
com_connect_out | 0 |
com_register_slave | 0 |
com_stmt_prepare | 22 |
com_stmt_execute | 22 |
com_stmt_send_long_data | 0 |
com_stmt_close | 21 |
com_stmt_reset | 0 |
com_stmt_set_option | 0 |
com_stmt_fetch | 0 |
com_deamon | 0 |
bytes_received_real_data_ps | 620872 |
