SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.001479
SELECT cache_value
Params: 1
Run Time: 0.000223
LIMIT 1
Run Time: 0.000569
WHERE
AND frtRead.read_date IS NULL
AND (frtThread.expire_date > 1714236640 OR frtThread.expire_date = 0)
AND view_global = 1
AND active = 1
ORDER BY frtThread.order
Params: 0
Run Time: 0.000403
FROM `xf_thread`
WHERE (`xf_thread`.`thread_id` = '3663')
LIMIT 1
Run Time: 0.000583
WHERE
AND (FIND_IN_SET (61, node_ids) OR node_ids = '')
AND active = 1
Params: 0
Run Time: 0.000405
SELECT cache_value
AND content_type = ?
AND content_id = ?
Params: 1, node, 61
Run Time: 0.000174
FROM `xf_post`
WHERE (`xf_post`.`thread_id` = 3663) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 60) AND (`xf_post`.`position` < 80)
Run Time: 0.002081
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 17 | Using index condition; Using where; Using filesort |
FROM `xf_attachment`
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (167959))
Run Time: 0.000425
-- XFDB=noForceAllWrite
INSERT INTO xf_thread_view
(thread_id, total)
VALUES
(? , 1)
ON DUPLICATE KEY UPDATE
total = total + 1
Params: 3663
Run Time: 0.000086
SELECT `xf_rm_resource`.*, `xf_user_User_1`.*, `xf_rm_resource_version_CurrentVersion_2`.*, `xf_rm_resource_feature_Featured_3`.*, `xf_rm_category_Category_4`.*, `xf_permission_cache_content_Permissions_5`.*
FROM `xf_rm_resource`
LEFT JOIN `xf_user` AS `xf_user_User_1` ON (`xf_user_User_1`.`user_id` = `xf_rm_resource`.`user_id`)
LEFT JOIN `xf_rm_resource_version` AS `xf_rm_resource_version_CurrentVersion_2` ON (`xf_rm_resource_version_CurrentVersion_2`.`resource_version_id` = `xf_rm_resource`.`current_version_id`)
LEFT JOIN `xf_rm_resource_feature` AS `xf_rm_resource_feature_Featured_3` ON (`xf_rm_resource_feature_Featured_3`.`resource_id` = `xf_rm_resource`.`resource_id`)
LEFT JOIN `xf_rm_category` AS `xf_rm_category_Category_4` ON (`xf_rm_category_Category_4`.`resource_category_id` = `xf_rm_resource`.`resource_category_id`)
LEFT JOIN `xf_permission_cache_content` AS `xf_permission_cache_content_Permissions_5` ON (`xf_permission_cache_content_Permissions_5`.`content_type` = 'resource_category' AND `xf_permission_cache_content_Permissions_5`.`content_id` = `xf_rm_category_Category_4`.`resource_category_id` AND `xf_permission_cache_content_Permissions_5`.`permission_combination_id` = '1')
WHERE (`xf_rm_resource`.`discussion_thread_id` = 3663)
LIMIT 1
Run Time: 0.001008
SIMPLE | xf_rm_resource | ref | discussion_thread_id | discussion_thread_id | 4 | const | 1 | |
SIMPLE | xf_user_User_1 | eq_ref | PRIMARY | PRIMARY | 4 | talo8211_xf.xf_rm_resource.user_id | 1 | |
SIMPLE | xf_rm_resource_version_CurrentVersion_2 | eq_ref | PRIMARY | PRIMARY | 4 | talo8211_xf.xf_rm_resource.current_version_id | 1 | |
SIMPLE | xf_rm_resource_feature_Featured_3 | eq_ref | PRIMARY | PRIMARY | 4 | talo8211_xf.xf_rm_resource.resource_id | 1 | |
SIMPLE | xf_rm_category_Category_4 | eq_ref | PRIMARY | PRIMARY | 4 | talo8211_xf.xf_rm_resource.resource_category_id | 1 | |
SIMPLE | xf_permission_cache_content_Permissions_5 | eq_ref | PRIMARY | PRIMARY | 35 | const,const,talo8211_xf.xf_rm_category_Category_4.resource_category_id | 1 | Using where |
- XF\Mvc\Entity\Finder->fetchOne() in src/addons/XFRM/ThreadType/ResourceItem.php at line 27
- XFRM\ThreadType\ResourceItem->adjustThreadViewParams() in src/XF/Pub/Controller/Thread.php at line 195
SELECT `xf_user`.*
FROM `xf_user`
WHERE (`xf_user`.`user_id` IN (25, 8349, 4081, 311, 3161, 10))
Run Time: 0.000514
SIMPLE | xf_user | range | PRIMARY | PRIMARY | 4 | | 6 | Using where |
FROM `xf_snog_forms_forms`
WHERE (`xf_snog_forms_forms`.`oldthread` > '0') AND (`xf_snog_forms_forms`.`oldthread` = 3663)
LIMIT 1
Run Time: 0.000680
SELECT view_date
FROM xf_session_activity
Params: 0, �`�
Run Time: 0.000159
UPDATE xf_session_activity
SET
ip = ?,
controller_name = ?,
controller_action = ?,
view_state = ?,
params = ?,
view_date = ?,
robot_key = ?
Params: �`�, XF\Pub\Controller\Thread, Index, valid, thread_id=3663&page=4, 1714236640, , 0, �`�
Run Time: 0.000131
bytes_sent | 16001 |
bytes_received | 890378 |
packets_sent | 172 |
packets_received | 1695 |
protocol_overhead_in | 6780 |
protocol_overhead_out | 688 |
bytes_received_rset_header_packet | 576 |
bytes_received_rset_row_packet | 215 |
bytes_received_prepare_response_packet | 115792 |
bytes_received_change_user_packet | 773113 |
packets_sent_command | 85 |
packets_received_ok | 0 |
packets_received_eof | 0 |
packets_received_rset_header | 64 |
packets_received_rset_row | 30 |
packets_received_prepare_response | 1446 |
packets_received_change_user | 125 |
result_set_queries | 26 |
non_result_set_queries | 4 |
no_index_used | 2 |
bad_index_used | 0 |
slow_queries | 0 |
buffered_sets | 0 |
unbuffered_sets | 0 |
ps_buffered_sets | 26 |
ps_unbuffered_sets | 0 |
flushed_normal_sets | 0 |
flushed_ps_sets | 0 |
ps_prepared_once_executed | 27 |
rows_fetched_from_server_ps | 99 |
rows_buffered_from_client_ps | 99 |
rows_affected_normal | 0 |
rows_affected_ps | 0 |
rows_skipped_normal | 0 |
rows_skipped_ps | 0 |
copy_on_write_saved | 0 |
copy_on_write_performed | 0 |
connect_success | 1 |
connect_failure | 0 |
connection_reused | 0 |
reconnect | 0 |
pconnect_success | 1 |
active_connections | 1 |
explicit_close | 0 |
implicit_close | 0 |
disconnect_close | 0 |
explicit_free_result | 0 |
implicit_free_result | 25 |
explicit_stmt_close | 0 |
implicit_stmt_close | 0 |
mem_emalloc_count | 0 |
mem_emalloc_amount | 0 |
mem_ecalloc_count | 0 |
mem_ecalloc_amount | 0 |
mem_erealloc_count | 0 |
mem_erealloc_amount | 0 |
mem_efree_count | 0 |
mem_efree_amount | 0 |
mem_malloc_count | 0 |
mem_malloc_amount | 0 |
mem_calloc_count | 0 |
mem_calloc_amount | 0 |
mem_realloc_count | 0 |
mem_realloc_amount | 0 |
mem_free_count | 0 |
mem_free_amount | 0 |
mem_estrndup_count | 0 |
mem_strndup_count | 0 |
mem_estrdup_count | 0 |
mem_strdup_count | 0 |
mem_edupl_count | 0 |
mem_dupl_count | 0 |
proto_text_fetched_null | 0 |
proto_text_fetched_bit | 0 |
proto_text_fetched_int | 0 |
proto_text_fetched_date | 0 |
proto_text_fetched_year | 0 |
proto_text_fetched_time | 0 |
proto_text_fetched_blob | 0 |
proto_text_fetched_enum | 0 |
proto_text_fetched_set | 0 |
proto_binary_fetched_bit | 417 |
proto_binary_fetched_short | 443 |
proto_binary_fetched_int24 | 160 |
proto_binary_fetched_bigint | 999 |
proto_binary_fetched_decimal | 32 |
proto_binary_fetched_float | 1 |
proto_binary_fetched_double | 2 |
proto_binary_fetched_json | 824 |
proto_binary_fetched_blob | 348 |
com_quit | 0 |
com_init_db | 0 |
com_query | 2 |
com_field_list | 0 |
com_create_db | 0 |
com_drop_db | 0 |
com_refresh | 0 |
com_shutdown | 0 |
com_statistics | 0 |
com_process_info | 0 |
com_connect | 0 |
com_process_kill | 0 |
com_debug | 0 |
com_ping | 0 |
com_time | 0 |
com_delayed_insert | 0 |
com_change_user | 0 |
com_binlog_dump | 0 |
com_table_dump | 0 |
com_connect_out | 0 |
com_register_slave | 0 |
com_stmt_prepare | 28 |
com_stmt_execute | 28 |
com_stmt_send_long_data | 0 |
com_stmt_close | 27 |
com_stmt_reset | 0 |
com_stmt_set_option | 0 |
com_stmt_fetch | 0 |
com_deamon | 0 |
bytes_received_real_data_ps | 770723 |
