SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.001343
SELECT cache_value
Params: 1
Run Time: 0.000206
LIMIT 1
Run Time: 0.000591
WHERE
AND frtRead.read_date IS NULL
AND (frtThread.expire_date > 1713533297 OR frtThread.expire_date = 0)
AND view_global = 1
AND active = 1
ORDER BY frtThread.order
Params: 0
Run Time: 0.000446
FROM `xf_thread`
WHERE (`xf_thread`.`thread_id` = '738')
LIMIT 1
Run Time: 0.000643
WHERE
AND (FIND_IN_SET (31, node_ids) OR node_ids = '')
AND active = 1
Params: 0
Run Time: 0.000434
SELECT cache_value
AND content_type = ?
AND content_id = ?
Params: 1, node, 31
Run Time: 0.000183
FROM `xf_post`
WHERE (`xf_post`.`thread_id` = 738) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 160) AND (`xf_post`.`position` < 180)
Run Time: 0.002097
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 19 | Using index condition; Using where; Using filesort |
-- XFDB=noForceAllWrite
INSERT INTO xf_thread_view
(thread_id, total)
VALUES
(? , 1)
ON DUPLICATE KEY UPDATE
total = total + 1
Params: 738
Run Time: 0.000089
SELECT `xf_poll`.*
FROM `xf_poll`
WHERE (`xf_poll`.`content_type` = 'thread') AND (`xf_poll`.`content_id` = 738)
LIMIT 1
Run Time: 0.000231
SIMPLE | xf_poll | const | content_type_content_id | content_type_content_id | 31 | const,const | 1 | |
- XF\Mvc\Entity\Entity->__get() in src/XF/ThreadType/Poll.php at line 24
- XF\ThreadType\Poll->adjustThreadViewParams() in src/XF/Pub/Controller/Thread.php at line 195
SELECT `xf_user`.*
FROM `xf_user`
WHERE (`xf_user`.`user_id` IN (3, 9516, 13, 7))
Run Time: 0.000492
SIMPLE | xf_user | range | PRIMARY | PRIMARY | 4 | | 4 | Using where |
FROM `xf_snog_forms_forms`
WHERE (`xf_snog_forms_forms`.`oldthread` > '0') AND (`xf_snog_forms_forms`.`oldthread` = 738)
LIMIT 1
Run Time: 0.000680
SELECT view_date
FROM xf_session_activity
Params: 0, t(�
Run Time: 0.000150
UPDATE xf_session_activity
SET
ip = ?,
controller_name = ?,
controller_action = ?,
view_state = ?,
params = ?,
view_date = ?,
robot_key = ?
Params: t(�, XF\Pub\Controller\Thread, Index, valid, thread_id=738&page=9, 1713533297, , 0, t(�
Run Time: 0.000134
bytes_sent | 12821 |
bytes_received | 700173 |
packets_sent | 160 |
packets_received | 1381 |
protocol_overhead_in | 5524 |
protocol_overhead_out | 640 |
bytes_received_prepare_response_packet | 87960 |
bytes_received_change_user_packet | 610828 |
packets_sent_command | 79 |
packets_received_ok | 0 |
packets_received_eof | 0 |
packets_received_prepare_response | 1150 |
packets_received_change_user | 115 |
result_set_queries | 24 |
non_result_set_queries | 4 |
no_index_used | 2 |
bad_index_used | 0 |
slow_queries | 0 |
buffered_sets | 0 |
unbuffered_sets | 0 |
ps_buffered_sets | 24 |
ps_unbuffered_sets | 0 |
flushed_normal_sets | 0 |
flushed_ps_sets | 0 |
rows_fetched_from_server_ps | 91 |
rows_buffered_from_client_ps | 91 |
rows_affected_normal | 0 |
rows_affected_ps | 0 |
rows_skipped_normal | 0 |
rows_skipped_ps | 0 |
copy_on_write_saved | 0 |
copy_on_write_performed | 0 |
connect_success | 1 |
connect_failure | 0 |
connection_reused | 0 |
reconnect | 0 |
pconnect_success | 1 |
active_connections | 1 |
explicit_close | 0 |
implicit_close | 0 |
disconnect_close | 0 |
explicit_free_result | 0 |
implicit_free_result | 23 |
explicit_stmt_close | 0 |
implicit_stmt_close | 0 |
mem_emalloc_count | 0 |
mem_emalloc_amount | 0 |
mem_ecalloc_count | 0 |
mem_ecalloc_amount | 0 |
mem_erealloc_count | 0 |
mem_erealloc_amount | 0 |
mem_efree_count | 0 |
mem_efree_amount | 0 |
mem_malloc_count | 0 |
mem_malloc_amount | 0 |
mem_calloc_count | 0 |
mem_calloc_amount | 0 |
mem_realloc_count | 0 |
mem_realloc_amount | 0 |
mem_free_count | 0 |
mem_free_amount | 0 |
mem_estrndup_count | 0 |
mem_strndup_count | 0 |
mem_estrdup_count | 0 |
mem_strdup_count | 0 |
mem_edupl_count | 0 |
mem_dupl_count | 0 |
proto_text_fetched_null | 0 |
proto_text_fetched_bit | 0 |
proto_text_fetched_int | 0 |
proto_text_fetched_date | 0 |
proto_text_fetched_year | 0 |
proto_text_fetched_time | 0 |
proto_text_fetched_blob | 0 |
proto_text_fetched_enum | 0 |
proto_text_fetched_set | 0 |
proto_binary_fetched_bit | 569 |
proto_binary_fetched_short | 437 |
proto_binary_fetched_int24 | 149 |
proto_binary_fetched_bigint | 940 |
proto_binary_fetched_decimal | 24 |
proto_binary_fetched_json | 727 |
proto_binary_fetched_blob | 361 |
com_quit | 0 |
com_init_db | 0 |
com_query | 2 |
com_field_list | 0 |
com_create_db | 0 |
com_drop_db | 0 |
com_refresh | 0 |
com_shutdown | 0 |
com_statistics | 0 |
com_process_info | 0 |
com_connect | 0 |
com_process_kill | 0 |
com_debug | 0 |
com_ping | 0 |
com_time | 0 |
com_delayed_insert | 0 |
com_change_user | 0 |
com_binlog_dump | 0 |
com_table_dump | 0 |
com_connect_out | 0 |
com_register_slave | 0 |
com_stmt_prepare | 26 |
com_stmt_execute | 26 |
com_stmt_send_long_data | 0 |
com_stmt_close | 25 |
com_stmt_reset | 0 |
com_stmt_set_option | 0 |
com_stmt_fetch | 0 |
com_deamon | 0 |
bytes_received_real_data_ps | 608602 |
