lewis a dit:Many thanks for your information. In China and some left hand drive countries, we have tested. But for belgium car, we are not 100% sure. So, do you need it to test?
ma réponse a dit:Hello,
I want to be a tester for the Belgian version (if this is based on your model corolla ...)
On a la trouve en UK et Australie sous l’appellation Corolla quelque chose ...J'ai l'impression que le problème est que l'Auris a été commercialisée uniquement en Europe.
lewis a dit:please confirm that we will not refund money to you if not working. And we can send you goods freely. Is ok?
Below is the link:
Aliexpress.com : Buy Hot salling car power window closer device high quality car window auto matically close from Reliable matic suppliers on zhongchengweishi Store
moi a dit:Hello ,
that makes the windows.
Not the locking of the car's doors while rolling!
lewis a dit:When you lock the door, it will roll the window. So, what function do you need?
lewis a dit:Hello
I think it is misunderstood;
the first option is when I start rolled that my car doors locked.
Camry/Corolla/Rav4/Prado voiture auto OBD dispositif de verrouillage de vitesse/voiture porte de verrouillage et dverrouillage module dans Cbles, adaptateurs et Douilles de Automobiles et Motos sur AliExpress.com | Alibaba Group
is ok: When you lock the door, it will roll the window. So.
SI is possible
sinon que le speed lock complet
lewis a dit:Camry/Corolla/Rav4/Prado voiture auto OBD dispositif de verrouillage de vitesse/voiture porte de verrouillage et dverrouillage module dans Cbles, adaptateurs et Douilles de Automobiles et Motos sur AliExpress.com | Alibaba Group
This product of this link can fit your product.
So, you need these two devices?
You can order at these two links.
lewis a dit:I apology that I make a mistake at my last reply.
The goods are not free, but shipping fee can be free. Is that ok?
moi a dit:OK, thanks ,
I started the first module.
see what it gives and so go step.
The second (more expensive) we will see later.
otherwise we risk mixing the follow-up and info.
ha bon et ou le boitier est fermé,non?Pour rappel, les fonctions sont gérables individuellement (désactiver/activer).
Si le vendeur ne t'a pas fourni les codes, tu peux les lui demander.
(Je peux te communiquer ceux que j'ai, mais pas certain du tout que ce soit les mêmes, vu qu'on ne parle pas du même véhicule...)
